Article ID : 00071434 / Last Modified : 23/07/2021Print
    How to import movies with the Apple iMovie software
    To import movies using the Apple iMovie software, follow the steps below.
    IMPORTANT
    • To import standard-definition video, the Apple iMovie '07 software or newer is required.
    • To import high-definition video like AVCHD, the Apple iMovie '08 software or newer is required.
    • You can't import AVCHD 60p (1080 or 720) into the Apple iMovie software. Additional information on how to transfer AVCHD videos to an Apple Macintosh computer is available.
    • For AVCHD videos, an Apple Macintosh computer with an Intel Core Duo processor or better is required.
    • If model-specific information is required to complete any of the steps in this solution, check the specifications or supplied operations guide. Manuals are posted on your model support page.
    Import movies using the Apple iMovie software
    1. Connect the camera directly to the USB port on the computer.
      NOTE: If the Apple iPhoto application programme starts automatically, close it.
    2. Open the Apple iMovie software from the dock or on the Finder Bar, Choose Go → Applications. The Apple iMovie software will be listed as an icon in the Applications window.
      iMovie
    3. In the Apple iMovie software window, click File → Import from Camera.
    4. Use one of the methods below to import videos.
      • Import all the videos:
        Automatic/Import All
        1. At the lower-left corner, click Automatic.
        2. At the lower-right corner, click the Import All button.
      • Import some videos:
        Manual/Import Checked
        1. At the lower-left corner, click Manual.
        2. Under the image icons displayed, click to check the boxes of the videos you want to import.
        3. At the lower-right corner, click Import Checked.
    5. Select the location to save the videos.
    6. In the Create New Event section, type a name for the videos.
    7. Click the OK button.
      NOTE: The videos now start being copied to the computer. An Import complete dialogue box will display when the import is finished.
    8. In the Import complete dialogue box, click the OK button.
      Import Complete/OK
    NOTES:
    • For information about editing a video, refer to the iMovie Help option.
    • If the Apple iMovie software can't import videos, check the Apple Web site for any current Apple iMovie software updates.
