Article ID : 00353771 / Last Modified : 04/11/2025Print
    Finding the right camera lens for your photography style
    The right camera lens can make all the difference between a good photo and a truly great one. With various lens types available, each suited for different shooting situations, it's important to choose the right one for your needs. This article explores the most common lens types, as well as ideal shooting scenarios, key features, and recommended focal lengths, to help you bring your photographic vision to life.
    Before You Start
    Fixed Focal Length (Prime) Lenses
     Assorted macarons on a plate, with a pink macaron in sharp focus and the rest softly blurred, captured with a prime lens.
    Focal length ~ 50 mm
    Best For:
    • Portraits
    • Low-light shooting
    • Cinematic visuals
    • Dramatic background blur
    Key Features:
    • Smaller in size and lighter in weight (so they're easier to hold and carry)
    • Offers wide apertures (f/1.2–f/1.8)
    • Enhances sharp features
    • Encourages more intentional composition and framing
    • Includes fisheye lenses, which offer ultra-wide, creatively distorted views at fixed focal lengths
    Ideal Focal Lengths:
    • 35mm: Great for environmental portraits and street photography
    • 50mm: For a natural look and everyday use
    • 85mm: Ideal for portraits
    • 135mm: For flattering headshots with background blur
    Zoom Lenses
     A zoomed-in view of a historic-looking building in the distance, framed by trees on both sides, captured with a zoom lens.
    Focal length ~ 135 mm
    Overview
    Need help choosing a lens? See our tips below.
    • Aperture size: Wider apertures (e.g. f/1.4) equal better background blur and low-light performance.
    • Weight and portability: Prime and compact zoom lenses (with a focal length of 18–55mm or 24–70mm) are easier to carry.
    • Subject: Wildlife? Go telephoto. Landscapes? A wide-angle lens is ideal. Travel? A standard zoom may cover it all. ​​​
    Visit our Support website for more shooting tips.
