macOS Big Sur(11.0) Compatibility Information for Application Software
We have checked the application software macOS Big Sur compatibility listed on this page.
IMPORTANT: Operation is not guaranteed for all computers.
Application Software | Version | Applicable Product Categories | macOS Big Sur (11.0) | Notes |
Imaging Edge Desktop (Remote/Viewer/Edit) *64-bit only | 3.0.01 | Cyber-shot α (Alpha) | Under Evaluation | This software is not currently compatible with macOS Big Sur. |
PlayMemories Home | - | Handycam Cyber-shot α (Alpha) Action Cam Bloggie / Webbie Digital Recording Binoculars | Not Support | |
Action Cam Movie Creator | - | Action Cam | Not Support | |
IPTC Metadata Preset | 1.1.00 | Check the supported devices | Compatible | Excludes Mac computers with Apple Silicon |
Remote Camera Tool | 2.2.00 | Check the supported devices | Under Evaluation | |
PlayMemories Camera Apps | - | Cyber-shot α (Alpha) | Under Evaluation | Refer to the Notice / Maintenance information section of the software website |
Imaging Edge Webcam | 1.0.00 | Check the supported devices | Compatible | Excludes Mac computers with Apple Silicon |
HEIF Converter | 1.0.00 | Check the supported devices | Compatible | Excludes Mac computers with Apple Silicon |
