Article ID : 00256621 / Last Modified : 18/01/2021
macOS Big Sur(11.0) Compatibility Information for Application Software
    We have checked the application software macOS Big Sur compatibility listed on this page.
    IMPORTANT: Operation is not guaranteed for all computers.
    Application SoftwareVersionApplicable Product CategoriesmacOS Big Sur
    (11.0)
    Notes
    Imaging Edge Desktop (Remote/Viewer/Edit)
    *64-bit only
    3.0.01Cyber-shot
    α (Alpha)
    Under EvaluationThis software is not currently compatible with macOS Big Sur.
    PlayMemories Home-Handycam
    Cyber-shot
    α (Alpha)
    Action Cam
    Bloggie / Webbie
    Digital Recording Binoculars
    Not Support
    Action Cam Movie Creator-Action CamNot Support
    IPTC Metadata Preset1.1.00Check the supported devices CompatibleExcludes Mac computers with Apple Silicon
    Remote Camera Tool2.2.00Check the supported devices Under Evaluation
    PlayMemories Camera Apps-Cyber-shot
    α (Alpha)
    Under EvaluationRefer to the Notice / Maintenance information section of the software website
    Imaging Edge Webcam1.0.00Check the supported devices CompatibleExcludes Mac computers with Apple Silicon
    HEIF Converter1.0.00Check the supported devices CompatibleExcludes Mac computers with Apple Silicon
