Article ID : 00243047 / Last Modified : 20/01/2026Print
I can’t use Side sense when I close the cover
    You can use the Side sense function on the right side of your mobile phone even if the cover is closed. To use Side sense on the left side, you need to open the cover.
    If the Side sense function isn’t responding, make sure it's enabled on the right side.
    1. Find and tap SettingsDisplayAdvancedSide sense.
    2. Tap Sensor enabled. Make sure on both sides or on the right-hand side is selected.
