Article ID : 00169106 / Last Modified : 21/10/2020
How strong is the waterproof or shockproof performance of the Waterproof Case and Underwater Housing?
    Waterproof and shockproof performances of the Waterproof Case and Underwater Housing are noted below.
    NOTE: The waterproof and shockproof performance was evaluated according to Sony's test criteria.
    Waterproof performance:
    • SPK-AS1 (sold separately) is operable up to a water depth of 60 m.
    • SPK-AS2 (bundled) is operable up to a water depth of 5 m for 30 minutes.
    • SPK-AZ1 (bundled) is operable up to a water depth of 5 m for 30 minutes.
    • SPK-X1 (bundled) is operable up to a water depth of 10 m for 60 minutes.
    • MPK-UWH1 (bundled) is operable up to a water depth of 60 m for 30 minutes.
    Shockproof performance:
    Conforms to MIL-STD 810F Method 516.5-Shock standards
    This product has passed testing when dropped from a height of 1.5 m above a 5-cm thick plywood board.
    NOTE:
    • Use the Waterproof Case/Underwater Housing which is compatible with your camera.
    • Depending on use conditions and circumstances, no guarantee is made regarding damage to, malfunction of, or the waterproof performance of this camera.
    • The camera without the Waterproof Case does not meet waterproof and shockproof specifications.
