Article ID : 00168093 / Last Modified : 02/11/2020Print
There is a long delay when trying to load Blu-ray Disc® (BD) movies
    Due to the large amount of information stored on a BD-ROM disc, it may take some time for certain discs to load. To decrease the load time and shorten the startup time when turning on the player, set the Quick Start Mode to On.
    Follow the steps below to set the Quick Start Mode setting:
    IMPORTANT: When Quick Start Mode is set to On, the power consumption will be higher and the ventilation fan may remain on depending on the surrounding temperature.
    1. Using the supplied remote, press the HOME button.
    2. Press the left arrow or right arrow to select Setup.
    3. Press the up arrow or down arrow to select System Settings.
    4. Press ENTER.
    5. Press the up arrow or down arrow to select Quick Start Mode.
    6. Press ENTER.
    7. Press the up arrow or down arrow to select On or Off.
    8. Press ENTER.
