How to disable or enable Internet Protocol Version 6 (IPv6) (Windows 7)
Disabling IPv6 may resolve Wi-Fi and WLAN connection issues, such as dropped or failed connections. Some older WLAN or Wi-Fi routers or access points may not support this protocol.
- Click the Start button and then click Control Panel.
- In the Control Panel window, click Network and Internet.
- In the Network and Internet window, click Network and Sharing Centre.
- In the Network and Sharing Centre window, in the left pane, click Change adapter settings.
- In the Network Connections window, click to select Wireless Network Connection and then on the menu bar, click Change settings of this connection.
NOTE: If Change settings of this connection is not available, click the right arrow to display it, as shown in the image below:
- To disable Ipv6, in the Network Connections Properties window, under This connection uses the following items:, click to uncheck the box next to Internet Protocol Version 6 (TCP/IPv6) and then click the OK button.
NOTE: To enable IPv6, click to check the box next to Internet Protocol Version 6 (TCP/IPv6) and then click the OK button.
- Close the Network Connections window.
