Article ID : 00162776 / Last Modified : 29/03/2019Print
    How to access the Settings options in the menu of the Internet TV device
    The following methods can be used to access the Settings options:
    1. From the Home menu:
      1. On the remote control, press the Imagebutton.
      2. On the home bar, use the arrow keys on your remote to highlight All Apps and then press ENTER.
      3. On the All Apps menu, use the arrow keys on your remote to highlight Settings and then press ENTER.
    2. From a search:
      2. Enter the word settings into the quick search box and then press ENTER.
