The network update warning keeps appearing when using the Internet video feature.
To make sure that the player has the latest firmware for playability improvement, it is normal for the network update warning to appear every time you want to use the Internet video feature.
When the warning appears, select OK to perform the update if needed. Canceling the network update will prevent you from using the Internet video feature.
