Check the following if the color of the image is not correctly displayed.
NOTE: The following functions may not be available on some models.
- This may occur if NightShot or NightShot plus for high-sensitivity recording is activated.
- Make sure the following settings are correct.
- White Balance
- Scene Selection
- Picture Profile
- Gamma Disp. Assist
- If the Auto Back Light function is activated, the camcorder adjusts the exposure towards plus, and it may make the image displayed bright or whitish. If your camcorder has a function to change the Auto Back Light setting, change it according to the subject.
