Article ID : 00089254 / Last Modified : 02/12/2015Print
When attaching the LCD semi-hard protective sheet, a rainbow pattern may appear on the sheet.
    If you press the centre of the protective sheet against the LCD screen, a rainbow pattern may appear. To eliminate the rainbow pattern, remove and re-attach the protective sheet.
    When attaching the protective sheet, align the black border of the sheet with the top right corner of the LCD screen and press the black borders of the sheet against the LCD to firmly attach it while holding down the black border.
