How do I change the AF Range Control value?
Follow the instructions below to change the AF Range Control value:
- Press the AF RANGE button or C (Custom) button several times until the shooting distance bar displayed on the screen turns orange.
NOTE: For the ILCA-77M2, the AF Range Control function is assigned to the C (Custom) button in the default setting. Once you have changed the assigned function, the AF Range Control function cannot be operated with the C (Custom) button. - Set the maximum shooting distance using the Front control dial and set the minimum shooting distance using the Rear control dial.
