Article ID : 00135593 / Last Modified : 30/06/2021
How to transfer pictures or movies from the camera to a computer using USB connection
    Select the appropriate computer operating system for the procedure to transfer pictures or movies using a USB connection:
    IMPORTANT:
    • Make sure the camera supports USB connectivity and the operating system installed on your computer. To check the specifications of the camera and for other model-specific information, refer to the camera instruction manual.
    • To transfer images from the internal memory of a camera, the recording media must first be removed. Not all cameras have an internal memory.
    • Transferring pictures using a USB connection depends on both the capabilities of the camera and the operating system installed on the computer. It may also vary depending on the model.
    Computer operating systems:
