Article ID : 00164425 / Last Modified : 28/11/2016Print
    How to uninstall a program using the program uninstall utility
    Follow these steps to uninstall a program using the program uninstall utility.
    NOTE: Some 32-bit applications include an uninstall utility that will allow simple and complete removal of all associated files.
    1. Click the Start button, point to All Programs, point to the desired program folder, then click the desired program uninstall icon.
      NOTE: The desired program uninstall wizard will begin.
    2. Follow the on-screen instructions.
      NOTE: If the desired application does not uninstall properly, reinstall the program  and try again.
