What does it mean when a Blu-ray Disc movie is Mastered in 4K?
IMPORTANT: This article applies only to specific products and/or operating systems. Check the Applicable Products and Categories section of this article before starting these steps.
What is Mastered in 4K?
Sony Pictures Home Entertainment has released Blu-ray Disc movies Mastered in 4K and Optimized for 4K Ultra High Definition Televisions. These Blu-ray Disc movies include the following technologies to yield the greatest possible high definition picture quality, and will upscale to create a satisfying 4K experience:
- Utilization of 4K movie masters created either from a film source scanned digitally with more than 4K resolution, or shot with 4K digital cameras that provides a more precise and detailed picture.
- The utilization of x.v.YCC color gamut to the 4K movie master delivers an expanded range of rich color contained in the original source when viewed on a high definition television compatible with x.v.YCC specification.
- Sony worked together with Sony Pictures to optimize the algorithms of down-converting 4K movie masters to upscale it with the Sony 4K-Reality Pro Engine, when viewed on a 4K LED TV.
Steps to Activate Mastered in 4K Function
This function is to optimize and provide picture quality suitable for Blu-ray Discs Mastered in 4K.
Steps to Activate Mastered in 4K on Your Blu-ray Disc Player
- Connect your Blu-ray Disc player to the HDMI input of your TV.
- Set the HDMI signal output from your Blu-ray Disc player to 1080/24p.
- ON the Blu-ray Disc player's remote control, press the HOME button.
- Select Setup.
- Select Screen Settings.
- Select Output Video Resolution.
- Select 1080/24p.
- Play any Blu-ray Discs with Mastered in 4K title.
Steps to Activate Mastered in 4K on Your TV
NOTE: Steps vary depending on the TV model.
For TVs Connected to BRAVIA Sync
- Choose between Cinema or HDR Video.
- On the TV remote control, press the SYNC MENU button.
- Select TV Control.
- Select Options.
- Select Scene Select
- Select Cinema or HDR Video.
- To activate Mastered in 4K function
- On your TV's remote control, press the SYNC MENU button.
- Select Home (Menu).
- Select Settings.
- Select System Settings.
- Select Picture.
- Select Mastered in 4K.
- Select On.
For TVs Not Connected to BRAVIA Sync
- On your remote control, press OPTIONS button.
- Select Scene Select.
- On your remote control, press the HOME button.
- Select Settings.
- Select Picture.
- Select On.
