Article ID : 00058153 / Last Modified : 21/10/2020Print
Where is the NFC antenna located in the camera?
    If your camera supports files transfers using the NFC function, the location of the antenna will be indicated with the following mark:
    The location of the NFC antenna is different depending on the camera model. This is due to the design of the camera and where the NFC module is best located in each camera body.
    Here are some examples of where the mark can be located. Check the instruction manual supplied with your camera to determine the specific location of the NFC mark.
    NFC mark ILCE-5000/6000
    ILCE-5000 / 6000
    NFC mark DSC-HX400
    DSC-HX400
    NFC mark DSC-W200/350
    DSC-WX220 / 350
    NFC mark DSC-HX60
    DSC-HX60
    NFC mark ILCE-7/7R
    ILCE-7 / 7R
    NFC location for DSC-QX10/100
    DSC-QX10 / 100
