Article ID : 00164496 / Last Modified : 28/11/2016Print
How to disable the power management setting for the wireless adapter
    The procedure to disable the wireless adapter power management settings varies depending on the operating system installed on the computer. Follow the appropriate link below to disable the power management setting for the wireless adapter.
