Article ID : 00120377 / Last Modified : 25/05/2022
Can I listen to High-Resolution Audio content from my Walkman on portable speakers?
    Yes, you have the possibility to listen to High-Resolution Audio content from your Walkman on Sony Portable speaker units, although this is only possible with compatible Hi-Res speaker models such as:
    • SRS-X9
    • SRS-X88
    • SRS-X99
    Connect a Walkman that supports High-Resolution Audio to theImage(USB) port on the rear panel of the unit using a High-Resolution Audio USB Adaptor WM-PORT Cable (WMC-NWH10) and output High-Resolution content digitally.
    NOTES:
    • While you will not find the adaptor in standard electronics stores & retailers, you can get the WMC-NWH10 optional High-Resolution Audio USB adaptor from either Sony certified Service Centres, or order it online from the EET Europarts website, our official partner. The link points to the correct part, with the part number X25884921. All you need to do to place your order is press BUY and follow the on-screen instructions.
    • The Walkman is not charged when connected to the unit using a High-Resolution Audio USB Adaptor WM-PORT Cable (WMC-NWH10, not supplied).
    • If you connect the USB DAC AMPLIFIER, the playing time of a Walkman connected with the unit will be shorter than when not connected.
    Example of the connection between the Walkman and the USB DAC AMPLIFIER:
    [A] Walkman that supports High-Resolution Audio
    [B] WM-PORT (22 pin)
    [C] High-Resolution Audio USB Adaptor WM-PORT Cable (WMC-NWH10)
    [D] USB cable (Depending on the model, this is not necessarily supplied. For details, refer to the instruction manual of the model.)
    [E] Image(USB) port of the USB DAC AMPLIFIER
