Article ID : 00060245 / Last Modified : 03/12/2015Print
    Some images look noisy when using the viewfinder of the camera
    The image may look noisy depending on the subject when using the viewfinder of the camera.
    To produce a better image in the viewfinder, you can increase the number of processed pixels displayed in the view finder by changing the Display Quality setting of your camera. Follow these steps to change the Display Quality setting:
    1. On the camera, press Menu.
    2. Select Setup.
    3. Go to Display Quality.
    4. Select High.
