Article ID : 00060460 / Last Modified : 04/12/2013Print
    Do I need to pay for using "Home Theatre Control" function?
    The Home Theatre Control Widget is free.
    To get the "Home Theatre Control" application from internet, you will need a network connection. Therefore, you need to have a contract with an internet service provider.
    Before installing the widget, check that the TV is updated with the latest software version by using "check software updates" function of the TV. How to check for software updates is also explained in the i-Manual in the TV.
