Article ID : 00061952 / Last Modified : 12/12/2013
Computer freezes on blank screen during shut-down
    When facing this issue, you can remedy by holding the power button for a while. The unit will shut down.
    McAfee update needed
    To avoid repeating or prevent the issue, a McAfee update is needed.
    As soon as you are connected to the internet, the update will be automatically pushed to your computer within the 4 coming hours. Any version equal or above 12.8.856 contains the fix. The version can be checked in the VAIO menu, via Programs and Features.
