Article ID : 00145499 / Last Modified : 21/08/2018
The light on the front of the TV is too bright
    You can reduce the light by setting the Illumination LED.
    For Android TV:
    1. Press the HOME button on the remote.
    2. Select Settings.
    3. Select Illumination LED in the TV category.
    4. Select Dark, Simple Response or Off.
    For 2014 models:
    2. Select Settings.
    3. Select General Set-up.
    4. Select Illumination LED.
    5. Select Dark, Simple Response or Off.
