Article ID : 00075712 / Last Modified : 12/07/2018
The buttons on the touch panel do not respond at the correct position.
    If this happens, use the calibration function in the menu.
    Calibration menu screen.
    Notes
    • If you did not press the right spot, try the calibration again.
    • Do not use a sharp-pointed object for calibration. Doing so may damage the LCD screen.
    • You cannot calibrate the LCD screen if it is rotated, or closed with the screen facing out.
