Article ID : 00078276 / Last Modified : 21/10/2020Print
What are the differences between HS120, HS100 and SSLOW?
    Although the three have the same frame rate, their recording formats are different.
    SSLOW
    • Super slow recording
    • Movies shot at a 120p/100p frame rate are recorded at 30p/25p
    • No audio is recorded
    HS120/HS100
    • High speed recording
    • Movies are recorded at a 120p/100p frame rate
    • Audio is recorded
    NOTES:
    • It is possible to edit and play back high-speed recorded movies in slow motion using the Action Cam Movie creator.
    • You can create impressive movies with sound (or no sound) by combining normal-speed and slow-speed sequences inside one movie.
