Article ID : 00075559 / Last Modified : 12/07/2018Print
Can I use the Mount Adaptor (LA-EA1) with this camera?
    Yes, you can.
    Please note that Autofocus is only available when using Alpha lenses with a build in AF-drive (SSM/SAM type).
    The LA-EA1 supports the APS-C capture format only. When using this adapter on a 35mm full-frame E-mount camera, vignetting will occur. Use the LA-EA3 or LA-EA4 in that case, which support the 35mm full-frame format.
                          Iens
    NOTE: Depending on camera model, a firmware update for the lens and/or the adapter may be required. Please be sure to check support site of the product for any firmware update.
