Article ID : 00075556 / Last Modified : 02/12/2020Print
How to change the zoom level of Picture in Picture (PAP) when using a Touchpad remote control
    PAP displays two pictures side by side (e.g. connected device and TV program) on the screen simultaneously.
    You can change the zoom or picture size by using the Touchpad remote. Please use the following steps to adjust the zoom settings:
    1. Slide your finger up or down on the Touchpad using long strokes without pressing down.
    2. Keep your finger on the Touchpad for 2 or 3 seconds to change the zoom level.
    3. Release your finger from the Touchpad to lock the zoom level.
    Alternatively, you can use the supplied IR remote (press the up / down buttons repeatedly to change the level of zoom / picture size).
