Article ID : 00128580 / Last Modified : 03/02/2022Print
How to perform screen mirroring using NFC?
    IMPORTANT: Screen mirroring can be performed between the Blu-ray Home Theater System, AV receiver, and a mobile device using NFC if the mobile device is compatible with Miracast technology. Refer to the manual supplied with the mobile device for information regarding Miracast compatibility and the location or position of the NFC detection area.
    1. Press the MIRRORING button on the Blu-ray Home Theater System or AV receiver remote control .
    2. Hold the mobile device near the N- mark png65856.png on the main unit until the mobile device vibrates.
    3. Once the connection is established, the mobile device screen will appear on the television screen.
