Article ID : 00158115 / Last Modified : 25/05/2022Print
The Bluetooth speaker turns off after the reset button is pressed
    As part of the normal operation, the Bluetooth speaker will turn off after pressing the reset button. However, it will not automatically turn on. Press the Bluetooth power button button located on top of the Bluetooth speaker after it turns off from the reset process.
