The POWER indicator is flashing red
If the POWER indicator is blinking red, the portable speaker is in Protect mode. This may happen if you connect a device that is not compatible with the speaker or due to overheating. To resolve this issue, follow the steps below:
- SRS-X9
- Disconnect the power cord for two minutes.
- Reconnect the power cord and turn on the unit.
- SRS-X7, SRS-X77, SRS-HG1
- Push the RESET button on the rear or bottom of the speaker with a pointed object, such as a pin.
If you have followed the steps provided and the power indicator is still blinking red, a repair may be required.
