Article ID : 00158186 / Last Modified : 25/05/2022Print
Unable to connect to the Wi-Fi network using SongPal
    Please check the following.
    For Android smartphones:
    • Check if you've input the password of the access point properly.
    For iOS mobile device:
    • Depending on the security method of the access points, you may not be able to connect using Music Center (SongPal). If you fail to connect using Music Center (SongPal), please use the WPS button or PC.
