TV SideView app cannot control the BD Player and "Network connection error" appears when the button is pressed.
Please try the followings:
- Check your network connections. Ensure that your remote device and Blu-ray Disc Player are on the same local network.
- Restart (turn off then on) your remote device Wi-Fi connection.
- If your remote device is using a proxy, try turning the proxy setting off. Some remote devices cannot connect properly to the player when using a proxy.
