This message means that the selected station or service is currently not broadcasting.
You can press [TUNE + or -] to tune to another station.
If the "OFF-AIR" message appears continuously, please run the DAB auto tune manually following next steps.
1. Hold down [RADIO DAB/FM-SCAN] button until "INITIAL" and "SCAN?" appears alternately on the display.
2. Press ENTER.
3. Scanning will start.
Depending on the DAB/DAB+ services available in your area, the scanning may take a few minutes.
When scanning is complete, a list of available services is created.
Notes: The currently stored list of available services will be cleared once the DAB auto tune process has started.
If your country or region does not support DAB/BAB+ broadcasts, "NO SIGNAL" appears on the display.
