Article ID : 00184417 / Last Modified : 25/05/2022Print
How to listen to music from a mobile device through an NFC-capable device using one-touch connection.
    NOTE: Not all mobile devices are supplied with the  Near Field Communication (NFC) function. To see if your device is compatible with the NFC function , check the operating instructions of the mobile device.
    By holding an NFC-compatible mobile device near to the N-Mark on the unit, the unit and mobile device pair and connect by Bluetooth connection.
    1. Unlock the mobile device screen.
    2. Enable the NFC function of the mobile device.
      NOTE: For more information on how to turn on the NFC function of the mobile device, refer to the operating instructions of the mobile device.
    3. Hold the mobile device close to the N-Mark on the unit until the mobile device vibrates or plays a short sound.
      • Example of the N-Mark on the unit
        CMT-BT80W/BT80WB/BT60/BT60B
        Blu-ray Home Theater Systems
        GTK-N1BT
        HT-CT660
        LBT-GPX77/GPX55, MHC-GPX88/GPX77/GPX55/GPX33/GZX88D/GZX55D/GZX33D
        SHAKE-5/33/55/77
        HT-M77/M55/M22
        ICF-CS20BT/XDR-DS21BT
      NOTE:
      • Refer to the manual of the mobile device for the designated location to be touched on the mobile device.
      • If pairing and the Bluetooth connection fail, do the following.
        • If your remote device has an OS version older than Android 4.1, download and start the NFC Easy Connect application.
          NFC Easy Connect is a free application for Android remote devices that can be obtained from Google Play. (The application may not be available in some countries/regions.)
        • Remove any commercially available mobile device case from the device.
    4. Start playback on the mobile device.
      NOTE: The unit only recognizes and connects to one NFC-compatible device at a time.
