Article ID : 00106226 / Last Modified : 22/01/2019
What is the maximum file size that can be played from a USB device connected to my TV?
    If your BRAVIA television is a 2013, or older, model, the maximum file size supported is up to 2 GB.
    If your BRAVIA television is a 2014, or newer, model, the maximum file size supported are as follows:
    File System
    Max File Size
    Max hard drive size
    FAT16
    2 GB
    Not supported
    FAT32
    4 GB
    2 TB
    exFAT
    16 TB
    16 TB
    NTFS
    16 TB
    16 TB
    NOTE: Sony cannot ensure the compatibility between BRAVIA and non-Sony USB device.
