How do I pair my smartphone and audio device together via Bluetooth?
Follow these steps to test Bluetooth pairing on your smartphone:
- After touching the audio device, complete the connection according to the instructions displayed on the smartphone screen.
- Confirm that Bluetooth is enabled on the smartphone and that it's paired to the device.
- Remove the paired devices and try connecting them again.
- If the problem persists and you're unable to pair your audio device and smartphone together, you can connect them manually.
For further information on how to manually link devices via Bluetooth, refer to the instruction manual provided with your audio device.
