Article ID : 00105297 / Last Modified : 12/01/2015
When I try to start the "Navigation" mode, I get the following error message: "Required files not found. Insert memory card or re-install the TomTom Navigation app." What should I do?
    Please try turning off the product, and make sure that the SD card is properly inserted into GPS module.
