Article ID : 00159962 / Last Modified : 25/05/2022Print
How to register an app for the FAVORITE button of the remote control
    You can register one (1) app into the FAVORITE button of the remote control, so that you can launch it quickly at any time using the FAVORITE button. You can choose an app included from any of the following:
    • My Apps
    • Featured Apps
    • All Apps
    • Image
    Follow these steps to register an app as FAVORITE.
    1. Use the arrow buttons on the bundled remote control, to select the app that you want to register. Image
    2. Once the desired app is selected, press the OPTIONS button.
    3. Select Register as Favorite.
    4. Press the FAVORITE button on the remote control to check if the registered app will launch.
