Article ID : 00117748 / Last Modified : 16/01/2026Print
    What audio file formats does the car stereo receiver support?
    IMPORTANT: This is a model-specific solution, view the Applicable Products and Categories for this article to verify that these specifications apply to your model.
    The car stereo receiver supports the following audio formats.
    • MP3
      • bit rate: 8 kbps - 320 kbps (supports Variable Bit Rate (VBR))
      • sampling rate: 16 kHz - 48 kHz
      • file extension: .mp3
    • WMA
      • bit rate: 32 kbps - 192 kbps (supports Variable Bit Rate (VBR))
      • sampling rate: 32 kHz, 44.1 kHz, 48 kHz
      • file extension: .wma
    • AAC
      • sampling rate: 11.025 kHz - 48 kHz
      • file extension: .m4a, .mp4
    • WAV
      • bit depth: 16 bit
      • sampling rate: 44.1 kHz, 48 kHz
      • file extension: .wav
    • FLAC
      • bit depth: 16 bit, 24 bit
      • file extension: .flac
    NOTE: It may not be able to play back DRM (Digital Rights Management) protected files in some cases.
