Article ID : 00160180 / Last Modified : 14/07/2021
How to purchase the correct analogue extension cable?
    NOTE: For some TV models, the analogue extension cable is supplied. First, check if the analogue extension cable is supplied with your TV.
    It is necessary for the standards of the terminal on the BRAVIA to match those of the cable.
    Even if they appear the same, the standards (wiring specifications) may be different.
    Therefore, please select a cable with functions 1-4 arranged on the terminal as follows.
    If you use a cable of a different type, the image or sound signal will not be output correctly.
    The following diagram shows the detail and the connection of the analogue extension cable.
    [A]: Analogue extension cable (Not supplied for all TV)
    [B]: Terminal area of the side connecting to the BRAVIA
    [C]: RCA pin cable (Not supplied)
    [D]: TV
    [E]: VCR/Video game/ DVD player/ Camcorder, etc.
    ・ Functions are arranged in the following order from the tip of the terminal:
           1: Audio (Left (L))
           2: Video
           3: Ground
           4: Audio (Right (R))
    ・The size of the plug is 3.5 mm in diameter.
    NOTE: For details, refer to Connecting the TV in the Reference Guide.
