Article ID : 00120442 / Last Modified : 17/07/2019
What are the options in the Accessibility menu?
    The Accessibility menu allows you to customise certain options for your Sony's Android TV, such as:
    • Captions: Set TV captions (the availability of captions depends on the content)
      • Sub-categories: Display and Configure
    • Services: Talkback, Switch Access and Text magnification
    • Text to speech: Google's Text-to-Speech engine
    You can reach the Accessibility  menu by using the following path:
    [HOME] > [Settings]* > [SYSTEM PREFERENCES - Accessibility] > [Captions/Services/Text to speech]
     HOME
    Android - Home
    Settings*
    Android - settings
    Android - Accessibility
    Android - Captions/Services/Text to speech
    *NOTE: For Android Oreo (OSV-O), the settings icon is located in the top right-hand corner
