Article ID : 00122372 / Last Modified : 27/12/2023Print
Part or all of a recorded image is yellow, or belt-like contrast is recorded.
    This problem may occur in the kinds of situations described below. Read on to confirm the details.
    Still images:
    Videos:
    Still photography:
    A phenomenon like this may occur when pictures are shot under lighting conditions such as fluorescent, sodium-vapor, mercury-vapor, or incandescent lighting. This phenomenon is called flicker. If this phenomenon occurs, try the following.
    NOTE: Some functions may not be available depending on the model unit.
    • Adjusting the shutter speed.
      NOTES: Shutter speed settings to reduce flicker depend on the power supply frequency in your region. We recommend that you set the shutter speed to 1/50 in regions where it is 50 Hz, and to 1/60 in regions where it is 60 Hz.
    • On a camera that lets you adjust the setting for the electronic front curtain shutter, select Off.
    • On a camera that lets you set the Shutter Type, select Mechanical Shut.
    • Set the Anti-flicker Shoot. function to ON.
    Image photo Shutter speed
    Image 1/200 s
    Image 1/50 s
    When a low-intensity flash is used with high-speed sync at a high shutter speed, horizontal streaks may appear on the screen, due to tiny fluctuations in the amount of light emitted by the flash being captured. If this phenomenon occurs, try the following.
    • Reduce the shutter speed.
    Image photo Shutter speed e-front curtain
    Image 1/8000 s On
    Image 1/1000 s On
    Image 1/8000 s Off
    Video recording:
    If you use an LED light, horizontal streaks may appear in the picture due to high-frequency flickering. Use a video light specially designed for video recording when you want lighting.
