Article ID : 00157071 / Last Modified : 25/05/2022Print
Cannot hear sound when a Walkman player or an Xperia mobile device is connected to the USB REAR or USB-B port
    When there is no sound output from the audio system or speaker while a Walkman® player or Xperia™ mobile device is connected to the USB REAR or USB-B port of the audio system or speaker, check any of the following:
    • Make sure that the selected FUNCTION is the same as the connector to which the device is connected to. Select USB REAR or USB-B mode according to the connector used for the connected device
    • When the Bluetooth® function of both the Walkman player or the Xperia mobile device and the audio system or speaker is enabled and the devices are connected via the USB REAR or USB-B port at the same time, audio may be output via the Bluetooth connection. Disable the Bluetooth function of the Walkman player or the Xperia mobile device
