Article ID : 00157047 / Last Modified : 03/10/2022Print
How to add a Google account to Sony's Android TV
    NOTE:
    Follow the steps below to set (add) a Google account on an Android TV.
    NOTE: The display screen may differ depending on the device or OS version. The following is just an example.
    1. Using the TV remote control, press the HOME button.
    2. Select Settings.
    3. Select Add account in the Personal or Accounts categories.
    4. Once the screen with account type options is displayed, select Google.
    5. Enter the Email address and select NEXT.
      NOTE: Use the Navi buttons to use the on-screen keyboard and press the center button to select.
    6. Enter the Password and select NEXT.
    7. After Signing in.. displays on the screen, if Success appears, the setting procedure is completed.
      After you have successfully logged in, the Google icon with the mark g will be displayed together with the email address used to log in.
    NOTE: You can delete your account, sync your account (Android OS7(N) only), or sync your apps by selecting the Google icon displayed.
