Article ID : 00135958 / Last Modified : 17/11/2015
There is no difference in image quality, even after the low pass filter setting was changed
    Depending on the shooting conditions, it may not be able to achieve the desired effect even when the optical low pass filter setting is de-activated. When increasing the aperture value past a certain extent, the sharpness of finely detailed objects may be lost due to light diffraction.
