Article ID : 00154477 / Last Modified : 12/05/2022Print
The LED indicators cannot be turned off when BT STANDBY mode is set.
The DIMMER button does not work when BT STANDBY mode is set.
    The LED indicators do not turn off when BT STANDBY mode is set to ON. This is based on specifications of the product.
    The DIMMER button is only effective on the LED indicators when the power is ON.
