Article ID : 00148990 / Last Modified : 16/01/2026Print
    What file formats can be played via the USB1 or USB2 ports?
    The following file formats can be played via the USB1 or USB2 ports.
    • MP3
    • AAC
    • WMA
    • WAV
    • FLAC
    • AIFF
    • ALAC
    • DSD (DSF, DSDIFF)
    NOTE:
    • For details, please refer to the manual supplied with the product.
    • DSD (DSF, DSDIFF) is supported at 2.8 MHz/1 bit, but it is converted to PCM during playback.
    • Decompressed files in FLAC format are also supported.
    • The following files are not supported.
      • M3U Playlist
      • Files with DRM
      • Multi-channel files
