Article ID : 00159055 / Last Modified : 27/12/2017
How do I playback a folder or file on the Blu-ray Disc Player?
    To playback a folder or file from a disc or a USB device on the Blu-ray Disc Player, choose any of the following methods:
    Using the PLAY button
    1. Using the supplied IR remote control, select a folder or file.
    2. Press the PLAY button.
    Using the ENTER button
    1. Using the supplied IR remote control, select a file.
    2. Press the ENTER button.
    Using the OPTIONS button
    1. On the supplied IR remote control, press the OPTIONS button.
    2. From the menu, select Play/View Image.
      NOTE: If you want to play a video or music file from the beginning, select Play from beginning from the menu.
