How to protect/cancel protection on recorded content
Please use the following steps below:
- Press the HOME button on the remote.
- Select Recorded Title List in the Apps category.
- Select the content that you want to protect/cancel protection on, and press the ACTION MENU button on the remote.
- Select Protect in the Recorded Title List category.
- Add a check to the programmes that you want to protect, or remove the check to cancel the protection.
- Select Set.
