Article ID : 00168019 / Last Modified : 16/01/2026Print
    Can I use the camera with setting Auto Pwr OFF Temp. to High all the time?
    Using the camera with Auto Pwr OFF Temp. set to High while holding it in your hand for a long period of time may cause low-temperature burns. You may keep Auto Pwr OFF Temp. set to High if using the camera with a tripod, etc.
